DasMainframe's avatar
DasMainframe
Initiate
Apr 25, 2016
Does the GS324 support 802.3ad dynamic?
I'm looking to buy a R8500 Nighthawk and a GS324 24-port switch for my home network. However, I have found no information to indicate whether or not the GS324 supports the dual AD ports on the R8500 ...
  • JohnRo's avatar
    Apr 26, 2016
    Hello DasMainframe,
    Welcome to the community!
    The GS324 switch is only a passthrough (dumb) switch and I don't believe it supports LACP. It is non-configurable since it does not have any UI or management software. If you want a switch with LACP (802.3ad) you'll have to go with our Smart Switch models (PROSAFE series).
    Let us know if you have more questions.
    Thanks,
