barryb1
Jan 14, 2017Aspirant
Ethernet Switch compatible with Windows VISTA
 I just plugged in my Windows 10 ethernet cable, and my Windows VISTA ethernet cable.  I can't get on-line with my VISTA cable (tried 2 different cables).  All lights are green....  Help?!
- Jan 24, 2017
Thank you for ALL your help!! It works as I needed it to.
PS: Anyone in need of a ethernet 'switch' that I can't use?
Thank you!
DaneA
Jan 18, 2017NETGEAR Employee Retired
The cable modem you have can only provide one IP Address for just one client that is why even if you connect the FS205 directly to the modem, only one PC will be able to access the internet. The FS205 does not have the capability to provide IP addresses to each PC connected to it since its just a pass-through, unmanaged switch.
You need to have a router in between the cable modem and the FS205. Its because the router can provide private IP Addresses to all clients connected to the local network. I suggest you the network setup below:
From the diagram above, the modem is connected to the WAN port of the router. The FS205 is connected to one of the LAN ports of the router. The two PCs connected to the FS205 will be able to have internet access at the same time because the router will provide private IP address to each PC. You can also connect other PCs directly to other LAN ports of the router that are not being used and still can go online at the same time with other PCs.
For the router, I suggest you the FVS318Gv2. Kindly check the data sheet and comparison to other ProSAFE VPN Firewall Routers here.
DaneA
NETGEAR Community Team
barryb1
Jan 22, 2017Aspirant
So, I'm not trying to be a smarta** - I just get confused with all this "stuff".
If I understand, I not only need COX's cabled modem, but then also need a router, which I plug into the modem, THEN can attach the FS205?
I guess, looking around here, I have another "modem" or two, but not a router.
Can you recomment (if this is the case) a 'cheap' router?
Maybe I'll just put up with changing cables, and rebooting the systems.....
Thank you SO much for all this information, though!!
- DaneAJan 23, 2017NETGEAR Employee Retired
The FVS318Gv2 that I have suggested is ideal to business environment. As you have mentioned that you want a 'cheap' router, I believe you are referring to a router that will be used in a small office / home office (SOHO) environment. NETGEAR has a vast selection of WiFi home routers. Kindly check it here. You may also post your inquiries in the NETGEAR WiFi Home Routers here.
DaneANETGEAR Community Team
