barryb1
Jan 14, 2017Aspirant
Ethernet Switch compatible with Windows VISTA
 I just plugged in my Windows 10 ethernet cable, and my Windows VISTA ethernet cable.  I can't get on-line with my VISTA cable (tried 2 different cables).  All lights are green....  Help?!
- Jan 24, 2017
Thank you for ALL your help!! It works as I needed it to.
PS: Anyone in need of a ethernet 'switch' that I can't use?
Thank you!
DaneA
Jan 23, 2017NETGEAR Employee Retired
The FVS318Gv2 that I have suggested is ideal to business environment. As you have mentioned that you want a 'cheap' router, I believe you are referring to a router that will be used in a small office / home office (SOHO) environment. NETGEAR has a vast selection of WiFi home routers. Kindly check it here. You may also post your inquiries in the NETGEAR WiFi Home Routers here.
DaneA
NETGEAR Community Team
barryb1
Jan 24, 2017Aspirant
Will the N300 WiFi Router work?
