Digital999
Dec 07, 2022Luminary
FS108PNA -- Get RMA for replacement
I have a POE switch that has two failing ports. I cannot find out how to get an RMA for this product which has a "Lifetime Warranty" and is registered under my devices.
Either there is a failure in the web page or Netgear is hiding the support RMA number.
Any help would be appreciated.
- Digital999Luminary
That link leads into a circular set of web pages with no way to see hardware support.
BTW, I have been a Netgear user for the past 12 plus years with many products registered.
And that is why I requested help -- failing hardware that is registered and covered under hardware warranty but the only link is to go to the 'community forum'.
Does Netgear employ humans that can help?
Did you try contacting them via phone?
https://my.netgear.com/support/contact.aspx
There's a business number on there.
