gshir's avatar
gshir
Follower
Jan 31, 2017
GS 108 Gigabit Switch Westell ADSL2 + Router set up
I have a Westell ADSL2 + Router (model F90 610025-06) on my DSL. I have a NetGear GS 108 Gigabit Switch (unmanaged) hooked up out of the Router and 3 devices plugged into the Switch (Apple Mini, Wind...
  • JohnRo's avatar
    Feb 02, 2017
    Hello gshir,
    Welcome to the community!
    Since the GS108 is only an unmanaged switch there is nothing you can configure on that device. It appears to me that your modem/router is in bridge mode. The reason why your devices can go online one at a time is that the modem/router does not supply enough amount of IP addresses for the devices to use. Kindly have your ISP take it off bridge mode or make sure that there is enough IP addresses for all of your devices.
    Thanks,
ProSupport for Business
