Dan_Bate
Jan 04, 2019Aspirant
GS105 and Yale Smart Alarm / Swann CCTV DVR
Hi,
I have a Netgear GS105 which is connected from my Virgin Smart Hub 3.0 (in Modem Mode) by an ethernet cable. Then into the hub i have connected a Google Wifi Point (Works Fine). I have then tri...
- Jan 06, 2019
Hi Dan_Bate,
Welcome to the community! :)
Since the Virgin Smart Hub 3.0 is in modem mode and the GS105 switch is directly connected to it, you will need a router in between the Virgin Smart Hub 3.0 and GS105 switch. Otherwise, if its possible to set the Virgin Smart Hub 3.0 to modem/router mode then that would help. The router will be the DHCP server that will provide local IP address to the Swann CCTV DVR.
With regard to the connection between the GS105 switch and the Yale Smart Hub 2.0, have you tried other ports of the GS105 switch? Also, try changing the ethernet cable.
DaneA
NETGEAR Community Team
DaneA
Jan 06, 2019NETGEAR Employee Retired
Hi Dan_Bate,
DaneA
