SAR1
Mar 20, 2018Aspirant
GS105 wont pass Broadband
Here is the issue. I have an ISP router (BT HUB 6) feeding broadband to a Netgear FS108 all works perfectly and I have a successful Broadband switched output from the other 7 ports. One of these ...
- Mar 26, 2018All sorted turned out to be an intermittent cable fault thanks
JohnC_V
Mar 22, 2018NETGEAR Employee Retired
Hi SAR1,
Welcome to our community! :)
These switches are unmanaged or plug and play devices. I suspect your broadband doesn't recognize the new connection from the switch. You may try turning off first the broadband, then once it boots up, you may now turn on all the switches that you have. Kindly attach a network diagram for better understanding of your network.
