SAR1
Mar 20, 2018Aspirant
GS105 wont pass Broadband
Here is the issue. I have an ISP router (BT HUB 6) feeding broadband to a Netgear FS108 all works perfectly and I have a successful Broadband switched output from the other 7 ports. One of these ...
- Mar 26, 2018All sorted turned out to be an intermittent cable fault thanks
JohnC_V
Mar 26, 2018NETGEAR Employee Retired
SAR1,
I would like to have a follow up on this thread. Please let us know if everything is ok now or you still need further assistance.
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
SAR1
Mar 26, 2018Aspirant
