ggraeff's avatar
ggraeff
Tutor
Aug 31, 2020
GS108 dropping internet whenconnected to Xfinity gateway
Hello - since needing to add more LAN connected devices to my home network to support work and school from home, I added a GS108 switch to my network.  I have Xfinity Gb internet, using the XB6 gatew...
  • ggraeff's avatar
    ggraeff
    Sep 02, 2020
    Hello, and thank you for getting back with me.  I believe that I have finally identified that problem.  This morning, I upgraded my Xfinity gateway the the XB7 (to eliminate it as part of the problem), which has four LAN ports, so I was able to isolate my critical home automation hubs to it, and individually test the remaining devices on the switch.  It appears that I have an Aukey USB hub, which has a LAN port, that has been failing, but also working for periods of time.  This morning, it seems to be failing all the time, as plugging it in will immediately cause all nodes in the switch to drop.  I'll be doing more testing, including the CAT6 cable running to that room, but I believe I've identified that the problem isn't the fault of the switch.
    Thank you for you help!
ProSupport for Business
