ggraeff
Aug 31, 2020Tutor
GS108 dropping internet whenconnected to Xfinity gateway
Hello - since needing to add more LAN connected devices to my home network to support work and school from home, I added a GS108 switch to my network. I have Xfinity Gb internet, using the XB6 gatew...
- Sep 02, 2020
Hello, and thank you for getting back with me. I believe that I have finally identified that problem. This morning, I upgraded my Xfinity gateway the the XB7 (to eliminate it as part of the problem), which has four LAN ports, so I was able to isolate my critical home automation hubs to it, and individually test the remaining devices on the switch. It appears that I have an Aukey USB hub, which has a LAN port, that has been failing, but also working for periods of time. This morning, it seems to be failing all the time, as plugging it in will immediately cause all nodes in the switch to drop. I'll be doing more testing, including the CAT6 cable running to that room, but I believe I've identified that the problem isn't the fault of the switch.
Thank you for you help!
DaneA
Sep 02, 2020NETGEAR Employee Retired
Let us isolate the problem. Kindly answer the questions below:
a. What is the behavior of the port LED lights on the GS108 switch?
b. Have you tried changing the ethernet cables you are using?
c. If you will connect a PC directly to the XB6 gateway, is the internet access just fine?
d. Is your GS108 switch a GS108v4 (v = version)?
DaneA
NETGEAR Community Team
ggraeff
Sep 02, 2020Tutor
