Shenzou
Mar 15, 2025Aspirant
GS108 power supply
Hello, I have a GS108 switch. On the back it says that the power input should be 12V 0,5A. Can I use however a 12V 1,0A power supply (Netgear P/N 330-10101-01) or will there be any risk?
- Mar 16, 2025
You need the exact same voltage and polarity. For amperage you can have more but not less.
