jhg
Sep 02, 2024Aspirant
GS108LP power supply providing only 52.25v
I purchased a GS108LP back in 2019. I was never able to get it to provide POE power to a WiFi device, and getting no solution from support I just fell back to using an injector. One symptom was...
BrianL
Oct 07, 2024NETGEAR Moderator
Hi jhg,
Good day!
It seems that you are using the included PA that came with the switch.I am not certain why the power output is below what was advertised. Anyway, this should power up POE/POE+ devices out of the box with 60W POE budget using the PA that came with it. Can you share what type of POE/POE+ devices you tried in the switch?
You may want to look at the product installation guide with POE specs for more information.
Kind regards,
BrianL
