theoscho
Apr 06, 2016Aspirant
GS108v4 not working
I have replaced a broken switch from a different brand to this netgear. All LED's are blinking but i do not get internet connection on my PC's. Is there anything todo in the installation?
- Apr 07, 2016
I have detached all cables. Then i have connected each again one by one. The first three everything worked fine. Then the next one cable reproduced the problem. I replaced that cable with a new one out of the box and now all connections are working properly. So the conclusion: sometimes the solution is simple if you know where to look for.
Thanks for the support.
theoscho
Apr 07, 2016Aspirant
DaneA
Apr 07, 2016NETGEAR Employee Retired
Hi theoscho,
I am glad that you were able to isolate the problem and its all working now. Good job! :)
Feel free to post your future concerns here in the community.
Cheers,
DaneA
NETGEAR Community Team
