AndyPL's avatar
AndyPL
Follower
Jan 04, 2022
GS116 - are all ports equal?
I have recently had a few issues in my home network and have checked all the structured cabling.  All is now ok.  In doing so, I noticed that out of the 16 ports on my GS116, ports 1-4 seemed to get better speed of throughput than the others.  When our BB was only 50Mb/s this was not noticeable, but now I have FTTP at 500Mb/s, it is clearly an issue as some ports get much less throughput.
The GS116 is a full 32Gb/s switch, by which all ports SHOULD be able to run bi-directional 1Gb/s.  Clearly the BB router throttles to 500Mb/s, but why is there this apparent prioritisation by the port number on the Netgear switch?  Is this to do with the internal architecture?  Or is this a possible fault?
Thanks for any advice.
Andy
1 Reply
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    AndyPL,
    Welcome to the community! :)
    I suggest you to open a support ticket with NETGEAR Support here at anytime for a hardware check on your GS116.  If the GS116 is proven to be faulty, an online replacement will be processed for as long as its within the hardware warranty.
    DaneA
    NETGEAR Community Team
ProSupport for Business
