kmmcd
Apr 21, 2018Aspirant
GS116 & STP cable
The GS116 has what appears to be a ground lug on the rear. I measure 0 ohms resistance between the RJ45 jack metal frames and internal tabs and this lug. Presumably, the metal plug of a STP cable will contact these tabs. If I connect the rear lug to ground of another piece of equipment, will this switch effectively support STP shielding? The manual does not mention this lug, and the specification sheet indicates that the connectors are UTP connectors.
kmmcd wrote:The GS116 has what appears to be a ground lug on the rear. I measure 0 ohms resistance between the RJ45 jack metal frames and internal tabs and this lug. Presumably, the metal plug of a STP cable will contact these tabs.
Yes, of course.
Sure.
Looks like a mistake on the almost 10 year old data sheet of the GS116 - the newer GS116v2 data sheet (from around 2014) does no longer talk of UTP ports (what does make no sense - as there is perfect shielding/grounding capability in place).
1 Reply
Yes, of course.
Sure.
