jj1988uk's avatar
jj1988uk
Follower
Jun 05, 2022
GS305 with PS4: manual IP address / internet connection failed
If I connect my PS4 directly into the wall ethernet then it works fine
But I recently bought a Netgear ethernet switch (GS305) so that I can connect my PS4 via ethernet but also have my wireless router for other devices.
After connecting everything up, my PS4 couldn't obtain an IP address. So I concluded that my PS4 was trying to use the same IP address as another device on my network.
I managed to specify the IP address for my PS4 manually in the connection settings, but now Im getting the following:
  • Obtain IP Address: Successful
  • Internet Connection: Failed
I've noticed, when I test my internet connection on my console, that my 'default gateway' is blank... even though I've specified this in the settings?
  • FURRYe38's avatar
    Try another switch? Possible bad switch?
    Check your LAN cables as well. CAT6 is recommended.
    • schumaku's avatar
      schumaku
      Is this undefined wall-port configured to allow one computer only, or is a modem only' Each would allow one computer only, with just one IP address.
ProSupport for Business
