Mar 18, 2021Tutor
GS305P Amber Left light
Why is any port using an ethernet cable linked to 2 other eero routers in series have an amber left light above the port while the ethernet cable to just one eero router have a green left light above...
- Mar 18, 2021
Try swapping them around and try swapping cables. I've had a cat 6 cable with a bad connector on it.
713416
Mar 18, 2021Tutor
Yes I use Cat6 cables
I will check the eeros by switching them ... good idea
light is yellow not amber ... wrong word for the color
thank you
