Aws5573's avatar
Aws5573
Follower
Sep 01, 2021
GS305v3 IP address
I purchased the GS305 and I’m having trouble with my computer connecting to the internet. When I connect the Ethernet to the GS305 my computer recognizes a network but can’t reach the web. When I run the troubleshooter it says I don’t have a valid IP address. When I bypass the GS305 and plug into the Ethernet port, everything is fine. It was my understanding that the switch was essentially an Ethernet splitter so I could connect more devices, I’d that not correct? I also have a PS4 plugged into the GS305 and that isn’t having any online connectivity issues.
  • schumaku's avatar
    schumaku
    Permitting the cables are fine, an the link LEDs show up: Probably connecting direct to eg. a cable modem WAN port where only one IP is available?
    WIthout a NAT router only one device can connect as only one IP will be assigned to the port intended to connect a NAT router.
    • DW21's avatar
      DW21
      I'm having a similar issue. The switch is plugged into the modem (no router) and a Roku works fine plugged into the switch but the computer will not connect to the internet when plugged into the switch. It says there is an incorrect IP. Even if the computer is the only device plugged into the switch I get the same error.
      I would appreciate any help/suggestions!
      • schumaku's avatar
        schumaku
        This is not a switch problem, just a common standard for ISP modems (without a NAT router). As I wrote above:
        One device will get a public IP address assigned, other devices won't get an IP address assigned, modern devices might fall-back to an auto-assigned ZercConfig IP subnet address.
ProSupport for Business
