amozza
Feb 08, 2024Aspirant
GS316 Unmanaged Switch Not Providing Internet
Hello, I have a GS316 16 port unmanaged switch feeding my home network. My ISP router connects to the switch and then the switch feeds multiple wall outlets around the house and another 5 port sw...
Feb 09, 2024Guru - Experienced User
the only other thing I'd check would be the power supply. I've had more power supplies fail on me than unmanaged switches. Maybe yours is putting out just enough power to light up the leds. Luckily its a pretty standard 12v/1amp power supply. You probably have one rated the same (or higher amperage) that you could try with. Just make sure the voltage is exactly the same. Amps can be higher but not lower.
And if it doesn't work, shooties. Time for a new switch.
