Petraistda's avatar
Petraistda
GS316PP -> Rack mount kit?
Hi Community,
I already own a GS316PP unmanaged switch. I know, it's a wall mount / desk switch.
Nevertheless, I would like to use it on tour, so I would like to have it installed fix in my 19'' video rack case.
Do you know, if there is a rack mount kit? As there are three screw holes on each side, it seems to me as if.
Do you know any general mini clamps that will keep the switch on place on a rack shelf?
Yes, I know, there are rack mount solutions out there available. But why not use what I have?
Thanks a lot
Petra
  • schumaku's avatar
    schumaku
    Hello Petra,
    Interesting question. Some GS308P, GS316P, GS316PP early access samples indeed came with some sleek rack mount wings (and had the three requires screw holes on the sides) indeed. I remember well e.g. on Netgear's Amazon shop, these were listed as rack mountable. Appears this capability was removed later.
    Challenge Netgear support via https://my.netgear.com or email in case your switch is out of the support window  customer.service@netgear.com please.
    Regards
    -Kurt
    • Petraistda's avatar
      Petraistda
      Thank you very much, Kurt.
      It's a pitty they removed it but I'll give it a try asking the customer's service.
      Kind regards
      Petra
ProSupport for Business
