StuckOnWiFi
Aug 28, 2024Aspirant
GS605v5 - my wi-fi is working, but my computer's ethernet connection hasn't worked for days
My ISP is Spectrum. My modem (and their tests) indicate that I'm getting service. I have a Netgear switch that relays things to my Wi-Fi mesh system and to my PC. I've never had trouble with it...
- Aug 28, 2024
Has a power OFF of the ISP modem, switch and wifi system for 1 minute then back ON been performed?
Can you remove the GS series switch and directly connect the wifi system to the ISP modem/router?
What brand and model# is the ISP modem and router and wifi system?
What CAT# LAN cable are you using? CAT6 is recommended.
Aug 28, 2024Guru - Experienced User
- StuckOnWiFiSep 05, 2024Aspirant
Thanks so much for your reply, and I'm sorry for not following up.
About an hour after I posted, I was able to get it working by switching around the way everything was connected. I hadn't seen the notifications about replies and just noticed them today.
It honestly doesn't make any sense that it stopped working the other way...it had worked for a number of years...suddenly stopped...and then me making this seemingly pointless and redundant change fixed it?
But honestly, I'm happy with it as long as it's working. However, I will absolutely take your recommendation on the cables. A couple of them were only cat5 so I ordered new ones.
- FURRYe38Sep 05, 2024Guru - Experienced User
So how was it connected and how is it connected now that made it work again?
Ya CAT5 is only good up to 100Mbps. CAT5e or CAT6 is rated up to 1000Mbps which the switch supports.
