StuckOnWiFi's avatar
StuckOnWiFi
GS605v5 - my wi-fi is working, but my computer's ethernet connection hasn't worked for days
My ISP is Spectrum.  My modem (and their tests) indicate that I'm getting service.   I have a Netgear switch that relays things to my Wi-Fi mesh system and to my PC.  I've never had trouble with it...
  • FURRYe38's avatar
    Aug 28, 2024
    Has a power OFF of the ISP modem, switch and wifi system for 1 minute then back ON been performed?
    Can you remove the GS series switch and directly connect the wifi system to the ISP modem/router?
    What brand and model# is the ISP modem and router and wifi system?
    What CAT# LAN cable are you using? CAT6 is recommended.
ProSupport for Business
