Confused_in_ID's avatar
Oct 09, 2017
GS608v4 - Firmware Update?
Is there or is there not a firmware update to the NetGear GS608v4? I have an email message from NetGear urging me to updat the firmware; the website seems to say there isn't one for that model.
TIA.
  • JohnC_V's avatar
    JohnC_V
    Oct 10, 2017
    Confused_in_ID,
    You're welcome! I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
  • JohnC_V's avatar
    JohnC_V
    NETGEAR Employee Retired
    Hi Confused_in_ID,
    Welcome to our community!
    GS608v4 is an unmanaged switch. It is just a plug and play device and it doesn't have any GUI.
    You may check the reference here.
      • JohnC_V's avatar
        JohnC_V
        Confused_in_ID,
ProSupport for Business
