Acuttie
Apr 19, 2016Aspirant
Help setting up network w/ GS605
I am not sure how to set up my network and need help. I had a new home built with three lines running to different rooms and all leading to a cabinet/box in the laundry room where cable etc are hous...
- Apr 24, 2016
Hi Acuttie,
I'm afraid to inform you that your best option is to properly connect your existing networking devices. Connect the Cox cable modem to the WAN port of the Asus AC3100 wireless router. Then, connect the GS605 switch directly to a LAN port Asus AC3100 wireless router. Finally, connect the remaining 2 lines directly either to the other LAN port(s) Asus AC3100 wireless router or any LAN port(s) of the GS605 switch. :)
DaneA
NETGEAR Community Team
JohnRo
Apr 19, 2016NETGEAR Employee Retired
Hello Acuttie,
Welcome to the community!
The problem here is the switch, it is not where it is supposed to be placed. The setup should be modem-router-switch. The reason why you cannot get a connection from the other ports of the switch is because it does not have a DHCP server thus it cannot give the devices connected to it an IP address. The GS605 is only a passthrough switch and does not have the capability to provide an IP address and translate the internet connection.
Let us know if you have more questions.
Thanks,
