Acuttie
Apr 19, 2016Aspirant
Help setting up network w/ GS605
I am not sure how to set up my network and need help. I had a new home built with three lines running to different rooms and all leading to a cabinet/box in the laundry room where cable etc are hous...
- Apr 24, 2016
Hi Acuttie,
I'm afraid to inform you that your best option is to properly connect your existing networking devices. Connect the Cox cable modem to the WAN port of the Asus AC3100 wireless router. Then, connect the GS605 switch directly to a LAN port Asus AC3100 wireless router. Finally, connect the remaining 2 lines directly either to the other LAN port(s) Asus AC3100 wireless router or any LAN port(s) of the GS605 switch. :)
DaneA
NETGEAR Community Team
Acuttie
Apr 23, 2016Aspirant
Is there a product that will work with the way I currently have it set up ? A switch that will give those DHCP to all ports from the cabinet.
- DaneAApr 24, 2016NETGEAR Employee Retired
Hi Acuttie,
DaneA
