Aladine's avatar
Aladine
How to find the CPU in a network device ?
Hi,
As you know probably there is an open issue with "some" CPU, and as you also know a program is started by a competitor for the replacement of "some" devices. And I know, I know, I'm apologize, there is no link between the two statments ...
... But, I'm looking for a way to find the CPU installed in my switch.
Thanks
Aladine (because Aladin was already used).
  • Hi Aladine,
    I have seen the posts online regarding the issue with Aton C2000 processors. I have inquired this to our engineering team but it appears that this information cannot be disclosed to avoid misinformation. For these models switches CPU chips may be different across batches. I have searched most of our products, but only some of our ReadyNAS units maybe using the said CPU family chip.
    Thanks,
  • JohnRo's avatar
    JohnRo
    NETGEAR Employee Retired
    Hello Aladine,
    Welcome to the community!
    Can you post a link regarding the CPU issue? I'd like to know as well what is the  model number of the swicth you are referring to.
    Thanks,
    • Aladine's avatar
      Aladine
      Hi JonRo,
      My model is the GS116v2, an "in between" manageable switch.
      The issue what I spoke over is, of course, the Atom C2000.
      But as I wrote, I juste want to find the kind of the processor installed in the GS116v2 switch.
      The only Aladine with a white beard.
    • JohnRo's avatar
      JohnRo
      Hi Aladine,
      Thanks,
      • Aladine's avatar
        Aladine
        Hi JohnRo
        Thanks for the information.
        I consider this topic as close.
        Kind Regards,
        Aladine
ProSupport for Business
