lewissurewise's avatar
Mar 21, 2017
Is it possible to use 2 switches in parrallel
We already have a GS324 24 port swtich and are looking to buy another to expand to 48, however are not sure if we should use 2 24 port switches in parrellel, or to just but a single 48 port switch which would be much more costly
Input much appreciated
  • Hi lewissurewise,
    Welcome to the community! :)
    Its alright to connect another GS324 switch to your existing GS324 switch.  As far as I know, there is no limit on the number of NETGEAR unmanaged switches that can be daisy chained or be cascaded together.  However, be reminded that the best practice would be about 2-3 switches daisy chained or cascaded.  It is because each switch that you connect adds latency to the network.
    DaneA
    NETGEAR Community Team
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    Hi lewissurewise,
    DaneA
    • DaneA's avatar
      DaneA
      lewissurewise,
      I just want to follow-up on this.  Let us know if you have questions.
      Otherwise, if ever your concern has been answered / resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
      DaneA
ProSupport for Business
