Crasje
Feb 18, 2026Tutor
MS308 unstable connection
Hello, I just upgraded my old 8 ports Netgear Switch for the newer MS308. When Doing this I also upgraded my ethernet cables from Cat 5(e) to Cat8. Problem I have that since moving to this ne...
- Feb 26, 2026
Got a new one, works perfectly.. it was the switch!
Feb 18, 2026Guru - Experienced User
Crasje wrote:You would think 500mb/s is plenty but I just got out of a conference call that kept dropping me and also paused the video of my 3 colleagues reporting bad internet connection.
Video conferencing doesn't use anything close to 500 mbps. So this particular issue must have had a different cause.
- Are you seeing a lot of packet loss with the new switch? That could explain both the performance drop and the video conferencing problem.
- Were you using a corporate VPN when you were on the video call?
- Another possible cause was the CPU load on the PC you were using. Did you try rebooting when you saw the performance issue?
Crasje wrote:Any suggestion what else I can do? Does it look like something is wrong with the MS308 (like I think there is)?
As suggested above, I'd look next at packet loss. You should be able to see this in the switch web ui.
You could try putting back the old switch (using the new cabling) and see if the performance gets more consistent.
What multigig devices do you have (other than the switch)?
- CrasjeFeb 18, 2026Tutor
It is the MS308, it's unmanaged, no web interface option. Could I measure it someway from my PC?
Good idea about the old switch, will try that.
My Multigig devices are:
- 2 Switches (MS305 & MS308)
- The Sagemcom internet router from my internet provider
- Wifi access point and satellites (Orbi 870)
- My Windows desktop
- My Macbook pro
- The wife Macbook air
- iPad pro
- 2 iPhones
I was just think I moved the incoming cable only on the router, I can try moving both cables on the MS308.
- StephenBFeb 18, 2026Guru - Experienced User
Ping can give you some idea - running ping -n 1000 8.8.8.8 from the windows command line (cmd) will ping google's DNS server 1000 times (once a second) and give you a summary on how many pings succeeded. You can also do this on a Mac from terminal (ping -c 1000 8.8.8.8). You can also ping your router IP (or the Orbi) if you want to test a local connection - that takes the internet out of the equation.
- CrasjeFeb 19, 2026Tutor
Thanks, today I have installed the old switch again and will test the stability.
- CrasjeFeb 26, 2026Tutor
Hi,
I send the switch back and got a new one and now the issue is gone!!
Apparently there was something with the switch, so the issue is solved.
Ps for some reasons the pings were actually OK and consistently good.
