Crasje
Feb 18, 2026Tutor
MS308 unstable connection
Hello, I just upgraded my old 8 ports Netgear Switch for the newer MS308. When Doing this I also upgraded my ethernet cables from Cat 5(e) to Cat8. Problem I have that since moving to this ne...
- Feb 26, 2026
Got a new one, works perfectly.. it was the switch!
Crasje
Feb 19, 2026Tutor
Been on the old switch al morning, had a video conference which was stable and so far no slow i-net or even a drop of i-net.
I am afraid it is the switch.
Feb 19, 2026Guru - Experienced User
Crasje wrote:I am afraid it is the switch.
Can you still exchange it with the seller?
What model is the old switch?
- CrasjeFeb 19, 2026Tutor
Yes, in the Netherlands you are allowed to return anything within 14 days. I just wrote them an email explaining what I have done and ask them for a suggestion (the only one is return it).
The old switch is the GS108.
- CrasjeFeb 26, 2026Tutor
- StephenBFeb 26, 2026Guru - Experienced User
Great! Thx for following up.
