Crasje
Feb 18, 2026Tutor
MS308 unstable connection
Hello, I just upgraded my old 8 ports Netgear Switch for the newer MS308. When Doing this I also upgraded my ethernet cables from Cat 5(e) to Cat8. Problem I have that since moving to this ne...
- Feb 26, 2026
Got a new one, works perfectly.. it was the switch!
Feb 19, 2026Guru - Experienced User
Crasje wrote:I am afraid it is the switch.
Can you still exchange it with the seller?
What model is the old switch?
Crasje
Feb 19, 2026Tutor
Yes, in the Netherlands you are allowed to return anything within 14 days. I just wrote them an email explaining what I have done and ask them for a suggestion (the only one is return it).
The old switch is the GS108.
