eberhard223's avatar
eberhard223
netgear gs116pp stops working all 24 hours
hi,
am having a strange problem with my NETGEAR GS116PP PoE switch:
- After ~2 years, it stops working approximately the same time in the evening and stops channeling traffic
- Still, all lights are on
- Plugging it off and plugging it in, solves the problem
- It does not happen all days, and it does not happen exactly the same time - most likely late evening
- Before (within the first two years), it was working 24/7 without problems.
- This already is the second device, which shows the scheme.
Any ideas?
Thank you.
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    eberhard223,
    Welcome to the community! 🙂
    Kindly access the support page of the GS116PP switch here and click the "Guided Assistance" button and follow the online instructions to create a support ticket for a hardware check.  If the GS116PP has been declared faulty, be ready to submit a soft copy of the Proof of Purchase of it for warranty verification.  If the hardware warranty is still valid, an online replacement will be processed.
    DaneA
    NETGEAR Community Team
    • eberhard223's avatar
      eberhard223
      Well, opening a ticket shows, that it does not fall under garantuee.
      However, the hardware was bought with a so-called "ProSAFE Lifetime-Garantie", which I had expected to offer a lifelong garantuee.
      Why is that?
      • schumaku's avatar
        schumaku
        Es gibt einige überschaubare Anfoderungen dass Netgear den ProSAFE Lifetime Garantie-Verpflichtungen für nicht modifizierte Produkte nachkommt. Das Gerät muss über die üblichen offiziellen Verkaufskanäle beschafft worden sein, davon braucht man einen Kaufnachweis. Die gefoderte Produkte-Registrierung wird nach meiner Erfahrung auch nachträglich angenommen.
        Nicht wirklich kompliziert wenn man der beiliegenden Installationsanleitung folgt - ein paar Klicks und ggf. ein kurzer Text auf https://my.netgear.com/  FMI https://www.netgear.de/support/product/GS116PP.aspx#docs
        Why is that?
        What does the ticket state?
        Die Netgear-Kollegen können (anders als normale Community-Mitglieder wie der schreibende hier) ebenfalls auf das Support-System zugreifen. Der übliche Grund sind zumeist fehlende Angaben.
        eberhard223
        Well, 1) It was the 2nd device of this kind, which failed. 2) These kind of devices are normally a long time in a rack and expected to work without problems. So, even if there is warranty, it is cumbersome and creates friction. And 3) The mentioned lifetime hardware warranty process is also a cumbersome one. - Generous or not, I like devices which work as intended.
ProSupport for Business
