RonAZ
Feb 03, 2021Tutor
Netgear GS305 - Internet speed dropped from 340 to 27 since installing
My internet speed has dropped from 340 to 27 since installing the Netgear GS305. My Set Up: I have run a Cat7 Shielded cable that is directly connected into my router, to my home thea...
- Feb 09, 2021
The issue is resolved...it was "OE" Operator Error... Somehow when I installing the GS305 switch, with the lost of the ethernet connection, my Nvidia Shield switched from ethernet connection to Wifi. The 27 download speed was for Wifi not ethernet. I reset the Nvidia Shield to ETHERNET connection and the down load was 337.
The GS305 switch was working perfectly as it was designed to do.
RonAZ
Feb 09, 2021Tutor
