Blink61
Oct 18, 2017Aspirant
Netgear Prosafe GS105PE POE passthrough switch
Trying to power a conference room IP phone using this device. Source switch is Netgear GS724TP which is spec'd as IEEE 802.3af and works fine with direct connection. With GS105PE fed from GS724TP,...
Blink61
Oct 19, 2017Aspirant
Thank you John. It would appear that the Conference phone is likely Class 3 (or above). I've managed to solve by providing dedicated power. I've learnt somewhat about POE specs though!
JohnC_V
Oct 20, 2017NETGEAR Employee Retired
That's great! I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
