Messtori
Dec 23, 2022Aspirant
Netgear XS508 and GS110MX causing power outage
I am trying to use the 2.5Gb (Intel® I225-V) or 10Gb (Marvell® AQtion AQC107) ethernet port of my motherboard (Maximus XII Extreme) to connect to a Netgear XS508 and/or GS110MX switch. I have run...
Messtori
Dec 24, 2022Aspirant
schumaku Thank you very much for giving my issue a shot. I can confirm that there is no PoE in my network also the theory with water does not seem likely. Both switches I have, are in a completely enclosed and locked server rack in my storage room since they have been unboxed.
I was able to do further tests today and found other devices that cause this issue with the switches.
- HP USB-C Dock G5
- Intel® I219V, 1 x Gigabit LAN Controller(s) on a TUF B360
Other devices such as a HP EliteBook 840 G6 can be connected directly to the onboard ethernet jack without any problems.
- schumakuDec 25, 2022Guru - Experienced User
Whatever also PoE is mostly isolated.
If the fuse or breaker is blowing, there is AC where it does not belong and it has a way to zero or to ground. Due to cabling or a power supply issue. Hard do say which of the two switches and it's power supply is causing it. Time for warranty or safety replacement.
