hshah96's avatar
hshah96
Network Switches
Hi
Is it possible to get an unmanaged network switch, at least some 1Gb port and PoE.
Please let me know
Thanks
  • Hi hshah96,
    As far as I know, the NETGEAR unmanaged Gigabit PoE switch like the GS108P is already End-of-Life (EOL).  I suggest you to check the GS110TP which is an 8-port Gigabit PoE Smart Managed Switch with 2 Gigabit Fiber SFP.  You may also use the GS110TP just like an unmanaged switch.  Click on the links below to know more about GS110TP:
    GS110TP Product FAQs
    GS110TP Data Sheet
    DaneA
    NETGEAR Community Team
1 Reply
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    Hi hshah96,
    GS110TP Data Sheet
    DaneA
ProSupport for Business
