3ny
Aug 06, 2017Aspirant
New GS308 swith won't give internet and assignes a weird ip. is this for internet or just network pc
The porpused of the swith is give more ports to connect more divices to the internet right? I connecteda new gs308 from working netgear wifi routher to swith then divices tothe swith and there is no...
JohnC_V
Aug 09, 2017NETGEAR Employee Retired
Hi 3ny,
Welcome to the community!
GS308 switch is an unmanaged switch which is a plug and play device. No configuration needed for it to work. Please try to do the following:
- Connect a cable from the router going to the switch, make sure that the port do light up
- If it is not working, replace the switch with a computer and check if you are now going to receive an IP
- if it still not working, try to replace the cable and connect the computer, if it worked, then you may now connect the switch
3ny
Aug 14, 2017Aspirant
Does it matter to which port do i connect the cable? i since the switch is not mark like the wifi routher wndr700.
I tried all the port and i cannot get a divice connected to that switch to the internet
