alrcsd's avatar
alrcsd
Number of Device Limitations
How many GS105v5 and/or GS108v2 can be stacked together?  I have 4 rooms with just one cat5 connection and multiple devices,  I want to "homerun" to single switch connected to DSL.  Do not want to us...
  • DaneA's avatar
    Oct 10, 2016
    Hi alrcsd,
    Welcome to the community! :)
    Stacking is not supported on both GS105v5 and GS108 unmanaged switches.  I believe what you mean to say is to daisy chain or cascade the GS105v5 and GS108 unmanaged switches.
    As far as I know, there is no limit on the number of NETGEAR unmanaged switches that can be daisy chained or be cascaded together.  With the 4 rooms you have, I think approximately 2 to 3  unmanaged switches (either  GS105v5 or GS108) cascaded will do.  The length of the  ethernet cables you will use to connect the unmanaged switches should be less than 100 meters to avoid attenuation.
    To know more about the GS105v5 and GS108v4 unmanaged switches, kindly access the data sheet here
    DaneA
    NETGEAR Community Team
ProSupport for Business
