marcosgu
Apr 18, 2017Aspirant
ping a gs105v4 gigabit switch
Hi guys, First aplogies if theres already a step by step procedure on how to ping to this switch in this forum. I only have one computer available to me at the moment and I would like to simply ...
marcosgu
May 01, 2017Aspirant
Hi All,
Kohdee and ElaineP are correct. I could not execute a ping command successfully with the the switch in-line at all unless it was used to connect to say another computer perhaps (which is what I did).
XavierLL
May 01, 2017NETGEAR Employee Retired
Hi Marcosgu
Sorry for the confusion but as my colleagues commendted the GS105 it's an unmanaged switch you can not ping it.
However I would like to recommend that if you want to have more visibility on the network and more control to use our Web Managed Plus switches (GS105E) as they come with VLAN,QoS, Cable Health, Port Mirroring, Static LAG, etc...
Hope it helps!
Xavier Lleixa
NETGEAR CBU PLM
