Presley
Aug 26, 2017Aspirant
PoE on unmanaged switch
I was hoping to eliminate the need for PoE injectors by finding an unmanaged 24 port switch with PoE to power the WAPs and ArloQ+ cameras, etc. The switch will go in my AV rack. I use Control4 and un...
- Aug 27, 2017
Hi Presley,
On NETGEAR ProSAFE Managed Switches that supports PoE, there is no option to turn it into a dumb switch. However, you can opt not to use the configurable settings since PoE is enabled by default.
DaneA
NETGEAR Community Team
DaneA
Aug 27, 2017NETGEAR Employee Retired
Hi Presley,
DaneA
- PresleyAug 27, 2017Aspirant
Thank you.
- DaneAAug 28, 2017NETGEAR Employee Retired
You're welcome. :) Let me share the latest NETGEAR Business Products Catalog on this link.
Let us know if you have further questions. Otherwise, if ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Regards,DaneA
