Teenet
Jan 05, 2017Guide
Netgear GS116 v2 16 port switch Power led blinks
Hi, I just received a new Netgear GS116 v2 16 port switch, unpacked it and connected it to the power supply and to a network cable. Immediately I found out that the power led on the switch is blin...
- Jan 06, 2017
Hi Teenet,
There must be something wrong with the power supply, it could be grounded or damaged. You can also contact our support team to get a free power supply replacement.
Thanks,
JohnRo
Jan 05, 2017NETGEAR Employee Retired
Hi Teenet,
There might be a little mistake with the model number you have posted since the GS116v2 is NOT a smart switch. Can you please PM me the serial number of your device so that we can identify the correct model number? I cannot give recommendations for now since I am unsure on what model you are working on.
Thanks,
Teenet
Jan 05, 2017Guide
Oops, my bad... It's the Netgear Prosafe GS116Ev2...
Do you still need me to PM you the s/n ?
Thanks again! :smileyhappy:
