HannoZ's avatar
HannoZ
registration of gs105
Good evening - at least it was until I tried registering a new product.  First off the registration pages wouldnt load properly in chrome so had to resort to edge.  Registered the product and got confirmation email.  When I log in to the account, the product isnt listed and when I try the serial number it comes back with a message saying that it is registered to a different account.  Cant grt to support as The product doesnt come up as registered.  Has anyone else had theis issue and how did you get around this?
Thanks...
  • Thanks DaneA my products have reappeared in MyNetgear profife.  Thanks for getting that sorted.  Fun evening now setting up an Orbi...
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    Hi HannoZ,
    Welcome to the community! :)
    I inquired your concern to the NETGEAR Support Team and just found out that your GS105v5 switch is already registered under your name.  Kindly verify it in your end.
    DaneA
    NETGEAR Community Team
    • HannoZ's avatar
      HannoZ
      DaneA  Thanks for the reply.
      I received a confirmation email that the switch was registered however when I log in to MyNetgear, it is not listed as a registered product.  I also had an old router that was registered and that has disappeared from the list of registered products as well.
      What I think has happened is that I forgot about my account and then created a new one with the same email address - although I should have thought that that should have been raised as a potential problem at the time - and the new router has been registed under my old profile.  When I try to login, I get directed to my new profile hence the problem.  Hope that makes sense.
      Thanks.  Hanno
      • DaneA's avatar
        DaneA
        HannoZ,
        I inquired your concern to the NETGEAR Support Team and found out that both the GS105v5 and WNR2200 registered under your name.  However, I still reported your concern about what you see in your MyNETGEAR account.  I will post here once I got a feedback.
        DaneA
ProSupport for Business
