cid681
Aug 22, 2016Aspirant
Replacement of FS105 with GS108
Hi, I'm new and have been looking for an answer online but can't find one. I am in need of additional network ports in my living room and my FS105 5 port box is being replaced with a new GS108 8 ...
- Aug 23, 2016
Hello,
Boy, I have egg on my face for this one. Quite an interesting one. To answer your questions, yes and yes it was new. And the set up works, now that I've set it up how I actually diagrammed.
It seems that I had not only a coaxial cable to my DVR1 but my cat6 network cable (not plugged into the Slingbox) as well. So I'm figuring the uverse system found conflicting signals inputting to my DVR and somehow crashed my internet/tv.
I even had a guy come out from AT&T, replace my modem (which was so old he'd never seen it before), and look behind my equipment to see if he could find the problem. It wasn't until after he left that I plugged and test ran each individual device into my old 5-port FS105, had the same crashing, until i found the one cable that caused it. And thus, it led to the DVR when I followed it.
Problem, solved, stupidly...
Thank you for your time and please keep this situation as a learning experience,
John
cid681
Aug 23, 2016Aspirant
Sorry if it seems rather crude. I wasn't sure how else to display a diagram.
So it starts from the wall > modem > gs108 > devices. I should also add that I plan to use my pre-existing FS105 in the room with the Uverse DVR 2 to an Amazon Fire TV and Roku 2.
JohnRo
Aug 23, 2016NETGEAR Employee Retired
Hi cid681,
The diagram is understandable, I have no complaints. This setup should work fine, I'm not seeing anything wrong with the setup. Are your devices getting an IP with this configuration? Is the GS108 brand new when you bought it?
Thanks,
- cid681Aug 23, 2016Aspirant
Hello,
John
- JohnRoAug 24, 2016NETGEAR Employee Retired
Hi cid681,
Don't worry, these things happen all the time, not just on small networks. :) It looks like a loop caused all the crashing. I'm glad that you have the network working now. If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution”, this will help other users just in case they ran into the same scenario.
Have a great day!
Thanks,
