Squiddley
Feb 02, 2019Initiate
Second GS205 connected to router not sharing internet
Hello community.... I cannot find specific answers to my problem amd appreciate help.
I have used one of these switches for 18months without issue. Connected to my R8000 router and the. To the ...
- Feb 04, 2019
Hi Dane
Thank you for the welcome. I bought a new 10m flat cat 6 cable, which works fine with the second GS205 now. The New GS205 is now a spare for future use. The problem must have been with the old flat lan cable, though why it failed to work with a switch yet was fine directly in the laptop lan socket is beyond me.
To avoid disppointment I also bought a TP-Link SG1005D 5 port gigabit switch that works too. It also didn’t like the lan old cable, so both hardware products are fine.
My issue is now resolved, and thanks for the follow-up.
Cheers!
DaneA
Feb 04, 2019NETGEAR Employee Retired
Hi Squiddley,
Welcome to the community! :)
I have interchanged he switches and the new one works with the old setup.
This means that the new GS205 is working.
My last resort will be a new flat cable,
Were you able to try another ethernet cable with the new GS205 switch? If yes, what is the result?
DaneA
NETGEAR Community Team
- SquiddleyFeb 04, 2019Initiate
Hi Dane
Cheers!
