Squiddley's avatar
Squiddley
Initiate
Feb 02, 2019
Second GS205 connected to router not sharing internet
Hello community.... I cannot find specific answers to my problem amd appreciate help.   I have used one of these switches for 18months without issue. Connected to my R8000 router and the. To the ...
  • Squiddley's avatar
    Squiddley
    Feb 04, 2019
    Hi Dane
    Thank you for the welcome. I bought a new 10m flat cat 6 cable, which works fine with the second GS205 now. The New GS205 is now a spare for future use. The problem must have been with the old flat lan cable, though why it failed to work with a switch yet was fine directly in the laptop lan socket is beyond me.
    To avoid disppointment I also bought a TP-Link SG1005D 5 port gigabit switch that works too. It also didn’t like the lan old cable, so both hardware products are fine.
    My issue is now resolved, and thanks for the follow-up.
    Cheers!
ProSupport for Business
