MarvinGS116's avatar
Jan 11, 2025
Streamer app not recognising streamers on wired network using GS116v2 but does when using GS108v4
Happy New Year
I have a question about communication between multiple streamers (Linn DSM’s) , Netgear switches , a Talktalk router and an IPhone
iPhone 13 ios18
Talktalk Sagecom 5364 router with FTTC
Netgear GS116v2 and GS108v4switches
Linn DSMs various with latest software
The Linns would autoplay when switched on but became flakey allowing the linn app(white) finding the rooms. I solved this originally by plugging them directly into the Router
With the prospect FTTP and using the Talktalk eero set up, I thought would try connecting everything through the GS116 switch but it became intermittent and I couldn’t group different Linns together
So testing began
Plugged the Linns into the router and all good
Then plugged them into a brand new switch (GS108v4) attached to the router (only Linn nil else) and all good
Then I tested each port on the GS116 switch by attaching a PC and using a broadband speed checker app on each one and they all worked
Then I plugged the Linn boxes and only the Linn boxes to the GS116 switch and they only worked intermittently
Then I plugged the linn boxes into the new GS108 switch on their own and all the other kit (TV’s,PC’s, network printer , access point in the garden) into the bigger GS116 switch and everything works. The switches each were connected to the router by their own cable
Does anyone have any ideas?
Obviously I have a solution but would prefer not to have to use 2 switches, because there are only 2 internet ports on the eero, one for the modem and one for the switch, when the full fibre comes.
Is the bigger GS116 switch broken? Or is it some other issue?
I have tried to log into the switch but cant
Thank you for your time and expertise
  • FURRYe38's avatar
    You sure you have a GS116v2 or do you have a GS116Ev2?
    The 116v2 is a non managed switch so no web page access and is just pass thru of all data traffic.
    The 116Ev2 is a smart switch so it has a management web page and some user configuration options.
    Be sure to check cableing. CAT6 UTP is recommended.
    • MarvinGS116's avatar
      MarvinGS116
      Tutor
      Hi
      Thanks for that
      It is GS116v2 ( no E or other letters)
      I have tried switching everything off and on in the suggested order
      Why does the new one work and the older one doesn’t?
      Cheers
      • FURRYe38's avatar
        So when using the 116 and 108 switches daisy chained works?
        Using them separately, doesn't work?
ProSupport for Business
