PattonSteel
Sep 07, 2016Aspirant
Switch loses internet connection
I got this 8 port switch from Netgear a while ago, I don't know what it is, and I can't open up the cabnet it is stored in right now to get the model number, but I can give this infromation: -It ...
- Sep 07, 2016
Editor Note: It was found that this particular switch was faulty and needed a replacement after doing troubleshooting steps below. If you have a similar issue please kudos and follow the steps here to have the switch replaced.
1. From your current network setup, disconnect the GS108 switch from the ethernet port on the wall.
Done
2. Connect your PC/laptop directly to the ethernet port on the wall.
Ok, it works, and I get ethernet and a valid IP. I can also go into my Asus router page
Questions:
a. Are you able to get a valid IP address if your PC/laptop is connected to the ethernet port on the wall?
Yes, and it is the same adress as if I connected it with a wire to the port on my router; the wire in the wall is direct to my cabnet, in my cabnet is a large bundle of wires.
b. Are you able to access the internet if your PC/laptop is connected to the ethernet port on the wall?
Yes
Let's continue with the steps below:
3. Connect the GS108 switch directly to the Asus router.
ok
4. While the GS108 switch is connected to the Asus router, connect your PC/laptop directly to the GS108 switch.
Ok done, and it works, but I still have had drops, and connection stops evey 20 minutes; it's even worse now that I am monitoring it.
Questions:
c. Are you able to get a valid IP address if your PC/laptop after doing steps 3 and 4?
Yes
d. Are you able to access the internet if your PC/laptop after doing steps 3 and 4?
Yes.
The problem that I am really having is that the ethernet will drop whenever it is connected to my switch....
So I guess my question is, If I return this swithc, and I get a managed switch, can I make it so that the one computer will have constant acess with no drops or packet loss at all?.
Is there any device which will split an ethernet connection from one ethernet wire to multiple? preferably to 7 other ports so I can keep all the outlets in my house with ethernet?
Thanks DaneA,
-PattonSteel
PattonSteel
Done
Questions:
Yes
ok
Questions:
Yes
Yes.
Thanks DaneA,
-PattonSteel
DaneA
Sep 08, 2016NETGEAR Employee Retired
Hi PattonSteel,
It seems that your GS108 switch is faulty. If your GS108 switch is still under hardware warranty, I suggest you to open an online case with NETGEAR Support at anytime. State the condition of your GS108 switch and the troubleshooting steps we've done to isolate the problem. Attach a .pdf or .doc copy of the Proof of Purchase or Sales Invoice of the GS108 switch on the online case for warranty verification. If the hardware warranty is still valid, then online replacement will follow.
A managed switch would also fit your network needs. You may check the links below to help you search the NETGEAR Switch model you prefer:
DaneA
NETGEAR Community Team
