starfry
Sep 14, 2017Aspirant
What is the difference between switches models FS524 and JFS524 ?
Hello, I have these two switches and I can't tell what is different between them except that the FS254 has lights on the ethernet ports whereas the JFS524 does not. Is that the only difference? T...
- Sep 14, 2017
Hi starfry,
Welcome to our community!
You are right but then, the differences between the 2 is that the FS524 is the older unit which only has a 5 years hardware warranty unlike the JFS524 which is already covered with the lifetime hardware warranty support.
JohnC_V
Sep 14, 2017NETGEAR Employee Retired
Hi starfry,
- starfrySep 15, 2017Aspirant
That is interesting. My JFS524 is dead so can I avail of the lifetime hardware warranty?
By "dead" I mean that the power supply is outputting no voltage.
- JohnC_VSep 18, 2017NETGEAR Employee Retired
You may create a chat / case online on NETGEAR support and also be ready with a soft copy of the Proof of Purchase or Invoice of the device for warranty verification. If ever the device is still under warranty, an online replacement will be provided.
- JohnC_VSep 21, 2017NETGEAR Employee Retired
I would like to have a follow up on this thread. Please let us know if you still need further assistance and just in case that the reply would be the answer to your issue. I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
