GrayHairCoder
Dec 18, 2020Tutor
BR200 losing connection and settings. Model drop down list wasn't showing the BR200 as a selection
Having connection issues with a newly installed BR200. It stayed connected for about 4 hours. It is my Firewall between my Century Link T1 Adtran router and my server. All of our employees RDP into t...
DaneA
Dec 22, 2020NETGEAR Employee Retired
It is strange that all configured settings are suddenly lost by the BR200 itself. After you have uploaded your save config file, does same problem happened again?
Was there a power outage that occurred where the BR200 is deployed?
DaneA
NETGEAR Community Team
DaneA
Dec 30, 2020NETGEAR Employee Retired
As far as I have checked, there is no issue on the BR200 wherein the configured setting will be erased by itself. Here are the steps I sguggest:
1. Reflash the firmware of the BR200. Kindly upload the latest firmware which is v5.10.0.4 to the BR200. You can download it here.
2. Perform a factory reset after reflashing the firmware.
3. Reconfigure the setting from scratch then save a backup of it.
Still a mystery so back to orginal question, should I be asking for a warrenty repacment?
If you have already performed the steps I suggested above and still the setting are erased by the BR200 itself, kindly open a support ticket with NETGEAR Support here as soon as possible for replacement.
DaneA
