it-ledmax's avatar
it-ledmax
BR200 with WAX610 connectivity problems
Hello,
I have a BR200 with some WAX610 APs that create a large wifi network.
After about 8 months of everything working fine I am dealing with a major problem :
Any device that I connect on the Wifi takes me to connectivitycheck.gstatic.com and askes me to sign in to the network.
Also, the computers that connect - show a no internet connection icon - but they receive proper IP's and do have access to the internet.
Any help or idea will help.
Thanks.
  • JeraldM's avatar
    JeraldM
    NETGEAR Employee Retired
    it-ledmax,
    Welcome to the community!
    Were there any events or any configurations performed that might have caused the issue?
    Are they connecting to the Guest WiFi or just the Wireless 1 network?
    Is the network being managed via NETGEAR Insight or just locally?
    Lastly, kindly check if the devices are updated to the latest FW (BR200 FW v5.10.0.5 and WAX610 FW v10.2.0.16).
    JeraldM
    NETGEAR Community Team
    • it-ledmax's avatar
      it-ledmax
      Hello,
      Everything is updated to the latest firmware.
      Network is managed via Insight.
      I turned off the Access Control List but nothing changed.
      Must be a setting in the BR200 router that I am missing.
      Any ideea is welcomed.
      Thank you.
      • JeraldM's avatar
        JeraldM
        Hi it-ledmax,
        Given that it's managed via Insight, have you tried creating a new SSID and connecting to it to see if it's the same issue?
        You may check this video for your reference.
        JeraldM
ProSupport for Business
