warsawtech
Feb 05, 2020Tutor
BR500 IPsec VPN dropping constantly
Haven't bothered opening a support case yet, just looking for input on what I might be overlooking. Since the Insight Instant VPN isn't working I decided to try and get the 2 BR500 setup with IPsec t...
JohnC_V
Feb 11, 2020NETGEAR Employee Retired
May I know if both BR500s are running on the latest firmware? You may also check this article on how to properly set up the Site to Site VPN to ensure that you didn't overlook anything.
John
NETGEAR Community Team
- warsawtechFeb 11, 2020Tutor
JohnC_V wrote:May I know if both BR500s are running on the latest firmware? You may also check this article on how to properly set up the Site to Site VPN to ensure that you didn't overlook anything.
John
Both routers are running FW 5.8.0.1. After installing the FW the Instant VPN stopped working. So I tried setting up the IPsec using the exact instruction you gave me a link too
- JohnC_VFeb 12, 2020NETGEAR Employee Retired
Please make sure that both routers are not on a double NAT setup and also the LAN subnet shouldn't be the same. May you be able to share the VPN logs on both routers?
John
